Micky Blue
*Update* Most of these parts now sold. Ignore list. Will make a new updated list soon.
Hi all. I hope everyone is keeping well.
I can't be sure I'm not breaking rules as this was originally a "cars for breaking", but this is the updated list of parts I have remaining from the Corrado I stripped a few years back. I'm not a commercial seller. These are all my own personal items and I just want them to go to a good home. Photos are avaliable on request, or you can see them in my older posts. Those previous posts are a bit messy as I'm not very computer literate, but I'm getting better. I also didn't have notifications on my phone, so I missed a couple PMs, which I can only apologise for. It won't happen again.
The part numbers should be accurate but only to the best of my abilities, so again, if you are unsure what a part is I can send photos. All parts are used and some have small amounts of wear, some are a bit rusty but as far as I'm aware, they are all in working order. Obviously full refunds if something doesn't meet expectations.
I also have pretty much every bit of wiring from the car, half of it cleaned up. I can't see it on the list for some reason, but for the lot I'm asking £150 collected and £200 delivered.
Part Number Part Name Price £ (Inc P+P)
O48103772 Oil breather valve assembly
10
O51133399F Fuel injection metering head cover trim
20
S6643K Clutch slave cylinder
15
357199353A Rear gearbox /engine bracket mount
22
051133357b, 051133373f, 051133997b, 048133455, 027133649d Air intake full assembly / tubing/ housing + Idle control valve
70
027103217e Crank case breather hose
10
535867587, 535867588 Boot lid left and right trim strips
25
535867591 Boot lid center trim
32
536853845, 536853830, 536853829 Water deflector scuttle panel trim, 3 pieces
50
535827873 Rear spoiler motor mounting bracket.
30
536937593A Fuse box bracket
18
536867180, 536867179 Interior door pull/ grab/ handle. Pair (can be sold seperately)
60
054133459b, 0280142153, 051133969a Fuel breather purge solenoid valve + bracket with rubbers + hoses
50
Item Sold Item Sold
Sold
535941535b Fog lamp switches
10
535959855E Passenger door window switch
12
535959621A Heated rear window switch
10
535941531 Headlight switch
25
535863284A Cigarette lighter
12
536823530 Bonnet pull lever
10
191853601H Front grille badge matte black
15
191853601 Rear VW badge
22
535857739, 535857740 Rear seatbelt latches
30
535867198, 535867197 Grab handles
15
536819724, 536819723, 536819361A, 536819081 Air vent housing/ guides 3 parts.
25
1220522017 Ignition coil/ transformer
12
536858061 Air vent grille cover trim
7
867881633 Seat tilt lever
15
535121343A Radiator cover trim piece
20
357937039 Fuse box
40
??? Rear view mirror
12
1H0907379B ABS ECU
20
358614141 ABS system reinforcement plate
25
192419523f Steering column joint rubber boot/ Gaiter
15
535867149D Karmann front speaker covers/ grilles PAIR
22
536857209, 536857210 Karmann dash speaker covers/ grilles PAIR
18
535953503P, 535953519A MFA, Wiper stalk, Indicator stalk and hazard switch assembly
28
321857961, 535864263a Center console/ handbrake tunnel cover INC rear ashtray (small crack rear hole)
25
535867601 Cover for rear tailgate/ bootlid lock
12
1ho 959855B Sunroof switch/ Interior light
15
??? Interior sunroof seal (felt grey)
22
261200858 ECU + retaining plate/ bracket
25
1ho919506a Cooling/ Radiator fan relay
10
535955713a Rear wiper motor
25
??? Wing mirror trim (interior door trianges) (Pair)
20
535419955 Power steering knuckle joint
22
535943121 Rear license plate light and bracket (some surface rust)
20
535867592 Bootlid interior trim/ cover (missing 1 fastner/ clip/ screw)
24
535867288, 535867287 C pillar trim (pair)
40
1H0O121407, 191121109K Coolant expansion reservoir and hose
18
120469689/ 690 Alternator
40
051063AA Throttle body
55
KS1054905377 Ignition detonation knock sensor
10
357199354H Engine mount bracket
25
??? Gearbox support bracket
30
536857104A, 536857125A Glove box and front flap, no cover
27
536857243 Instrument cluster/ speedo surround trim
25
536863240 Footwell/ floor air vent guide/ heating duct
25
536863240 ABS pump heat sheild. Rusty, needs blasting.
12
191012219 Original wheel nut brace/ socket wrench
15
357711188 Gearbox change balance weight
15
357927903A Harness for speed sensor loom
20
358614105 Brake servo
50
191422372b Power steering fluid reservoir
12
358614301 Brake master cylinder and fluid reservoir
25
536819707b, 536819707c, 536819708b, 536819708c Air vent rotary inserts set of 4
25
357955531 Wiper washer relay
12
191953227a Hazard + turn signal relay
6
857951253, 141951253b, 191937503, 857951253b Multi use relay – glow plug, fuel pump, horn
20
191955529 Rear wiper wash relay
8
535862254, 535862263 Sound absorber for central locking pump
12
535863858 Sound absorber set for seat support
22
535905851 No other part number. Steering column, no key!!
55
536857926 Stowage compartment
35
??? Full exhaust system excluding manifold. Not in great condition. Make an offer. Can be sold seperately
Offer
??? Carpet cover trim strips pair
45
  Luggage compartment wheelarch carpets.
30 each 70 all 3
  Front wiper motor mechanism
35
192819051, 192819355, 192819031c, 192819052A Complete air blower heater matrix ducting assembly
65
  Space saver spare wheel
35
  Gearbox full with drive shafts and steering rack still attached. 200 collected 300 delivered
300
  Carpet. Main floor
60
  Subframe assembly. Rusty. Needs blasting
100
  Under dash tray stowage compartment (passenger side)
25
358614117 ABS pump unit
70
535201355 Fuel line, fuel filter, supply
25
536721555 Throttle cable
25
535201374 Fuel feed pipe
15
  Under dash tray stowage compartment (driver side)
25
  Petrol tank (not complete)
Offer
  Door shut, kick plate decals
20
  Floor mats
25
  Engine (partly disassembled) (sold as one lot) Collection price 250, delivered 350
350.00
Edited by Micky Blue
No longer avaliable
On 5/1/2021 at 10:22 PM, Bruno said:
Is that exhaust still going? PM me with a photo please.
The exhaust has been sold I'm afraid. Beefore you messaged actually. I didnt get this notification till just now. Sorry mate, hope you manage to get one.
