1xshaunx1 27 Posted July 25, 2021 On 7/25/2021 at 2:54 PM, Ostkakan said: Yeah I saw that on the other side. Its from 93. Then I need to find same as ecs type 93 should later esc type with separate wire and plug. How was it connected befo Quote Share this post Link to post Share on other sites
Ostkakan 11 Posted July 25, 2021 On 7/25/2021 at 3:09 PM, 1xshaunx1 said: 93 should later esc type with separate wire and plug. How was it connected befo I have separate wire and plug on right side. I guess some later owner have change to old style Quote Share this post Link to post Share on other sites
Ostkakan 11 Posted July 25, 2021 On 7/25/2021 at 2:34 PM, 1xshaunx1 said: That sensor in your hand is for earlier Corrado’s and has the wire attached to it that goes through the wings. Later ones had the sensor that you show from ecs that has a separate wire from the sensor and you plug it in on the hub. Your car should be fitted with the same type though so I don’t know why you have both types. What year is your car Separate wire not easy to find, part number 357927903A. Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted July 25, 2021 Don’t think you are going to find a new one. It look to be a hens tooth. There is a 2nd hand one on English eBay going for £45 or a seller in Germany is selling 2 for 20€ but one of those is definitely damaged either that or message lilfuzzer on the forum to see if he has a good second hand one. With the post to EU at min the way it is the one from Germany is probably the best option. Quote Share this post Link to post Share on other sites
Ostkakan 11 Posted July 25, 2021 On 7/25/2021 at 8:08 PM, 1xshaunx1 said: Don’t think you are going to find a new one. It look to be a hens tooth. There is a 2nd hand one on English eBay going for £45 or a seller in Germany is selling 2 for 20€ but one of those is definitely damaged either that or message lilfuzzer on the forum to see if he has a good second hand one. With the post to EU at min the way it is the one from Germany is probably the best option. yeah i saw does on ebay, i made a bid on the 20€ one. Quote Share this post Link to post Share on other sites
Dox 28 Posted July 26, 2021 Have you measured the resistance of your sensors with an ohmmeter? Quote Share this post Link to post Share on other sites
Ostkakan 11 Posted July 26, 2021 On 7/26/2021 at 11:21 AM, Dox said: Have you measured the resistance of your sensors with an ohmmeter? Yes did it today, the sensor is dead. So i order a new one 🙂 Quote Share this post Link to post Share on other sites
Ostkakan 11 Posted July 28, 2021 Changed the sensor today, no more abs light. Car feels great no vibrations, Just don't put steering wheel on lock and accelerate 1 Quote Share this post Link to post Share on other sites
Ostkakan 11 Posted July 28, 2021 On 7/28/2021 at 4:03 PM, Ostkakan said: Changed the sensor today, no more abs light. Car feels great no vibrations, Just don't put steering wheel on lock and accelerate Quote Share this post Link to post Share on other sites
MackDM 0 Posted August 26, 2021 On 7/28/2021 at 4:03 PM, Ostkakan said: Changed the sensor today, no more abs light. Car feels great no vibrations, Just don't put steering wheel on lock and accelerate Great to hear changing the sensor clears the ABS light. We'll work on buddy's Corrado project after we finished installing the rack and bakflip cover on the truck this week. The Corrado is flashing the abs light and needs an alignment. Quote Share this post Link to post Share on other sites
