Bauhaus 3 Posted March 30, 2022 Does anybody know how to remove the plastic triangle trim piece by the door mirror on a 91 Corrado G60 ?. I think I need to remove both interior and exterior parts as I have a small water leak which trickles down the passenger door card and over the door speaker. Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted March 30, 2022 Inner just pops off with a flat edge, it only clips on. outer has a screw from the inside holding it place, there is a plastic cap on the screw head to be popped off Quote Share this post Link to post Share on other sites
Philly-R6 1 Posted March 30, 2022 Adding to Shaun, use a heat gun to get a little warmth in the plastic and slide the outside triangle off (toward the front of the car from memory). There is a flat plastic hook affair which slides into the metal door frame. Take your time and do not break it! Quote Share this post Link to post Share on other sites
Bauhaus 3 Posted March 31, 2022 Thanks for the replies gents.... I will be attempting to remove and fix this over the weekend, hopefully with no breakages 🙁 . Quote Share this post Link to post Share on other sites
Bauhaus 3 Posted April 2, 2022 Ok took the interior plastic triangle off but not sign of any nut to undo for the exterior part, I take it the three tabs that are visible are holding in the exterior triangle ? or am I wrong... I don't want to be breaking anything obsolete...does anyone know how the exterior bit comes off ? Quote Share this post Link to post Share on other sites
seanl82 23 Posted April 2, 2022 On 4/2/2022 at 5:50 PM, Bauhaus said: Ok took the interior plastic triangle off but not sign of any nut to undo for the exterior part, I take it the three tabs that are visible are holding in the exterior triangle ? or am I wrong... I don't want to be breaking anything obsolete...does anyone know how the exterior bit comes off ? It's the button just underneath the right hand side of the triangle in this pic. The button is a screw cover Quote Share this post Link to post Share on other sites
