Stone0311 0 Posted May 3, 2022 Hi All,Now finishing up wiring ect for my transplant but have a few loose ends, any help appreciated: Blue and Black temp sensors:I have 4 wires (plugs missing atm) which don't seem to match bentley:Brown, white/brown, brown/green, yellow/green Reverse switch:Can anyone confirm black/red and black/blue to plug? Oil pressure switches:Have Yellow which is high oil pressure? Also have blue/white and green/black, one of these is low oil pressure which don't seem to match my bentley? Not sure what the other is? I may have missed something obvious in the items above, loom is new to the car and engine Thanks Sent using Tapatalk Quote Share this post Link to post Share on other sites
Keyo 49 Posted May 3, 2022 (edited) The one shown loose does not connect to anything it left the factory tidy like that just leave wrapped up in loom . Seen this on a few g60 all the same- I will get the other bits for you . Edited May 3, 2022 by Keyo Quote Share this post Link to post Share on other sites
Stone0311 0 Posted May 3, 2022 @Keyo - Thanks m8, much appreciated Couple of others if you know: > Have a stray brown/white loomed up with the o2 pot sensor?> Have a blue cable with single plug which I understand to be the 'alternator excitor wire' - where does this connect? (image attached) Thanks in advance Sent using Tapatalk Quote Share this post Link to post Share on other sites
Keyo 49 Posted May 3, 2022 54 minutes ago, Stone0311 said: @Keyo - Thanks m8, much appreciated Couple of others if you know: > Have a stray brown/white loomed up with the o2 pot sensor? > Have a blue cable with single plug which I understand to be the 'alternator excitor wire' - where does this connect? (image attached) Thanks in advance Sent using Tapatalk Quote Share this post Link to post Share on other sites
Stone0311 0 Posted May 3, 2022 Thanks Sent using Tapatalk Quote Share this post Link to post Share on other sites
Stone0311 0 Posted May 30, 2022 Morning all, looking to run the engine loom as close to stock as possible, has anyone got any pics of the general cable route from the headwall nr the coil across the engine? In particular route from alt to starter, head to temp sensors/oil sensors and ISV Thanks Quote Share this post Link to post Share on other sites
Stone0311 0 Posted June 4, 2022 Got a green cable coming from the engine bay to the fuse box, test shows it coming from the digifant connector on the highlighted pin Anyone have any ideas? Can't seem to find it on any wiring diagrams Quote Share this post Link to post Share on other sites
Bauhaus 3 Posted June 4, 2022 if that is pin 16 on the G60 ecu connector then that wire is not used, unless you have aircon. Quote Share this post Link to post Share on other sites
Stone0311 0 Posted June 5, 2022 Thanks @Bauhaus 👍 Quote Share this post Link to post Share on other sites
Stone0311 0 Posted June 25, 2022 Anyone know the part number for these clips on a G60? Also interested if anyone has any 👍 Quote Share this post Link to post Share on other sites
