Stone0311 0 Posted June 11, 2023 Sure plenty have done this before but if not details attached for a simple 'lights on' alarm using 58e (Grey) and x (black/yellow) from the back of the headlamp switch.I used a 12v intermittent beeper for the alarm Sent from my SM-S901B using Tapatalk Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted June 11, 2023 Good tip I would advise to put a fuse on that brown wire. Cars have caught fire in and the past as when the switch packs in it can send heavy amps through that wire and it fry’s the back of the dash unless you can kill the power. I have experienced this almost disaster on 2 previous Corrado’s. It won’t happen to my current one though. Quote Share this post Link to post Share on other sites
fendervg 32 Posted June 11, 2023 (edited) You can use the standard VW lights on buzzer relay from a Mk3 or later, and run some wiring to it - I think it was an earth, feed from sidelights or dash illumination circuit and the driver's door contact switch - I did this about 10 years ago, but haven't looked at it in a while - I'll see if I can find anything in the archives. Edited June 11, 2023 by fendervg Quote Share this post Link to post Share on other sites
Stone0311 0 Posted June 11, 2023 Good tip I would advise to put a fuse on that brown wire. Cars have caught fire in and the past as when the switch packs in it can send heavy amps through that wire and it fry’s the back of the dash unless you can kill the power. I have experienced this almost disaster on 2 previous Corrado’s. It won’t happen to my current one though. Fuse on the factory ground? What size did you put in?Sent from my SM-S901B using Tapatalk Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted June 11, 2023 14 minutes ago, Stone0311 said: Fuse on the factory ground? What size did you put in? Sent from my SM-S901B using Tapatalk 5 amp. It’s the earth for the light in the switch Quote Share this post Link to post Share on other sites
Stone0311 0 Posted June 11, 2023 Thanks for the heads upSent from my SM-S901B using Tapatalk Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted June 11, 2023 No worries, it was my pleasure Quote Share this post Link to post Share on other sites
