Scott
Top Mounts
Just been out to trial fit my new GSF Grill spoiler (which fits A1 by the way) and found that one of my front top mounts (pass side) looks like it has collapsed.... :x
How difficult to replace?
Seeing as the mounts look cheap - do I replace ALL of them?
Or just do the front?
I am assuming the rears will be a no go because of the passive rear steering effect?
Can anyone help?
I have read it mate - very useful - doesnt actually say what bits I need though....
GSF have:
Top mount bearing
Top Mount
Top Mount Kit
I am assuming I need the kit per side for front? - £11 + VAT :lol: cheap!
What about rear? - worth doing?
Bump stops?
GSF have:
Top mount bearing
Top Mount
Top Mount Kit
Bump stops?
You don't need to do the rear at the same time, you can just do the front.
The kit is what you need (the part number should be on the how-to?). The kit has both the mount and bearing in it. Why they sell it as separate parts as well, I have no idea.
I didn't do the bump stop when I was in there... if there is one at all?
Well I am thinking to tighten the car up a bit about doing them all - worth it or not?
I need new shocks really but they are going to have to wait for a while yet... but the originals are not leaking or anything
Unless the bump stops are knackered, dont bother replacing them
it takes shag al time to do the front top mount once you have all the tools at hand
  Scott said:
should only need the 21mm swan neck spanner?
Well it depends on what you have already. According to the how-to...
  Quote
10mm spanner
13mm and 15mm for caliper sliding pins
17mm socket
18mm spanner
18mm socket
21mm swan neck ring spanner
5mm Hex socket attchment
Spring compressors
Vice
Some string
bloody great big breaker bar to fit 18mm
PlusGas
Big hammer
Big flat head screwdriver
Crosshead screwdriver (pref. impact) for disk locating screw
- If above fails, steel drill bit :)
Is what you need.
got everything except the 21mm swan spanner I think.... might even have one of them
Cheers :D
Cheers :D
you could always use a spark plug socket,with a big allen key to hold the strut still
I'd like to point out that the dousing of all the bolts in PlusGas overnight will make your life a million times easier. It's worth every penny.
  Scott said:
And some mole grips :lol: :lol:
nah the spark plug sockets ive seen have got flat sides so you can put a spanner on them
  Supercharged said:
  Quote
PlusGas?
WD40 not do it ?
PlusGas is alot more effective... :wink:
Halfords sell yes? :-P
