Andy Brookes 0 Posted September 3, 2004 Just been fitting my new (old) windscreen lower trims (thanks Dan Steele) and thought I would do a little maintance on the sunroof while I was tinkering. The sunroof had been working fine, but I thought I would grease it up as it looked a bit dry in there, I use some white spray grease......not so sure that was the right thing to use.....as I closed it to work the grease in, clunk, scatching noise...noooooooo. Yep you guessed it, the passenger side stuck and I know have missing paint work on that side of the sunroof. I knew it had to happen one day. So as a warning if my theory is true, dont use white grease??? Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted September 3, 2004 White grease should be fine - which bits did you lube though??? Quote Share this post Link to post Share on other sites
Andy Brookes 0 Posted September 4, 2004 both tracks, nothing else. All I can think is that the extra friction just tilted it over the edge, must have been waiting to go! Quote Share this post Link to post Share on other sites
Banana Man 0 Posted September 4, 2004 white grease is fine for hinges and the like so that shouldn't have been the cause maybe it was just a pure coincidence!! :( Quote Share this post Link to post Share on other sites
Mike Edwards 0 Posted September 4, 2004 Well, the bits of the tracks that the rear-most parts slide in are now easy to access with the roof in. Maybe with the front elements sliding smoothly, the lack of lube on the rear-most parts tipped it over the edge... Quote Share this post Link to post Share on other sites
Andy Brookes 0 Posted September 4, 2004 Arh well another job for the winter! Along with many others. Cheers Andy Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 4, 2004 I can't understand it mate.... there was no slack in your water plate guide. Normally when tilted, you would get a couple of mill vertical play if the guide was worn, but yours was solid. Put some masking tape on the roof and slide it back again just to see if it was a one off? I would use Castrol LM grease in there rather than white grease to be honest. Good to meet you today by they way! Quote Share this post Link to post Share on other sites
