Bally 0 Posted October 18, 2004 I now have a complete 2.0L 6a lump sitting in my garage.. big thanks to David for all is help.. :D I need some advise on what to do next, I no I have alot of prep work etc in order to get it in the car & plan to replace most of the parts before installing the lump.. I also have a polished 50mm inlet which I'm not sure on fitting? also thinking of having head/ported polished/gas flowed?? I'm looking for reliability & performance.. need some advise guys.. KevHaywire seems to no his stuff... so pls advise.. :?: Quote Share this post Link to post Share on other sites
Bobby 0 Posted October 18, 2004 i'm looking at doing exactly the same thing, mate. Quote Share this post Link to post Share on other sites
aposegil 0 Posted October 18, 2004 mate aslong as the engine was healthy before it came out you shouldnt have any problems Use u head and cams on the bottom end and that should keep u happy :) also if u want change the water pump on there and off course head gasket and geaskets before sticking it in as for the inlet personally i would stick to the 50mm one for the more fun as ive never noticed this fall in torque even on my other mates 16v that everyone keeps mentioning Quote Share this post Link to post Share on other sites
Bally 0 Posted October 18, 2004 hey Al. the lump seems to be in good nick, but am stripping it over the next few wks & get it looking mint again.. water pump & a metal head gasket are on my shopping list.. as for inlet, myns running the 42mm at mo.. would like to see what the 50mm does with the 2.0L... :D Quote Share this post Link to post Share on other sites
Henny 0 Posted October 18, 2004 If I were to be fitting a new engine, I'd definately whip off the sump, replace the oil pump and check the bottom end and big end shells while it was out of the car... The bottom end and big end shells are only about £40 all in for a 4cylinder VW engine and can be done without taking out the crank... I'd also be tempted to stick in some new piston rings so you KNOW that you've got a good bottom end which will last you a good 80K miles with no problems if treated properly for the first few hundred miles... 8) Quote Share this post Link to post Share on other sites
Bally 0 Posted October 19, 2004 Cheers for the reply Ian, plans are to replace whtever is worn etc.. want it to be reliable so wont be cutting corners! Quote Share this post Link to post Share on other sites
Bally 0 Posted October 19, 2004 Apart from david w & Alex with a charger & his nutty mate, anyone else running this conv? Quote Share this post Link to post Share on other sites
theRuler 0 Posted October 19, 2004 you could, as a suggestion, get the crank reground to suit new bearings. while you are having that done, get it balanced while you are in there, get the conrods all matched (to same weight) then balanced and have the whole lot "tuffrided" also shed some weight off the flywheel too. that'll make for a tasty and strong bottom end. shouldnt cost much, but in the long run, will be dope. Quote Share this post Link to post Share on other sites
theRuler 0 Posted October 19, 2004 i must add though - get the flywheel lightened PROFESSIONALLY tempting as it may be to machine bits off it, it can lead to disaster. i had a friend with a pug 1.9 gti 205, he lightened his flywheel himself, by drilling etc. it broke at high revs, went through the bellhousing on the box, and jammed into the passenger side footwell so hard it was poking through the floor. a "spare underpants" moment :shock: Quote Share this post Link to post Share on other sites
Bally 0 Posted October 19, 2004 Thanks for the reply mate, Flywheels on my list to be lightened & balanced.. will look into the other bits, cheers :D Quote Share this post Link to post Share on other sites
theRuler 0 Posted October 19, 2004 its well worth doing. a good machine shop / engineering place should be able to do the whole lot. when my vr6 motor dies, i will have that all done to it. it shouldnt cost that much either Quote Share this post Link to post Share on other sites
Bally 0 Posted October 19, 2004 I'm curently stripping the bottom end then I'll send it off to be played with :lol: Quote Share this post Link to post Share on other sites
