BigTartanJudge 0 Posted May 27, 2003 Hi all, Since VW have discontinued the OEM gauge pod / plate that was optional on G60 models I wondered if anyone on the forum has embarked on a DiY version to fit either in the same location (under ashtray) or in place of centre console heating vents or knows of someone that has. Looks like this is the only was to get gauges installed aside from fitting an A-pillar pod (which am doing anyway). Many thanks SCOTCORRADOG60 Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted May 27, 2003 i have a VDO. before that i made my own. If anything it fits better than the VDO. Buy a Black ring binder. draw around the cassette holder. WOrk out centres for guages. cut um with a circle cutter on a drill. Use 2 pieces of folder to make it bout 8mm thick. plenty rigid enough. mount gauges. I used sticky back velcro to secure it. glue a couple of plastic bloks on the card n stick the velcro in the bin. Job sorted. the black grain folders even look like proper stuff. the only downside it the gauges are not counter sunk unless you cut the holes in the top piece of folder bigger. Quote Share this post Link to post Share on other sites
G60 0 Posted May 27, 2003 what gauges are you using? i have a boost gauge on the a-pillar but i'm going to be buying an air/fuel and volts in the next couple weeks.. just curious if anyone has found the need for yet another different type of gauge. Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted May 27, 2003 Im using Summit racing AF and TIM (yes i know its cheap) oil pressure. Im gonna replace the oil with a Summit oil to match. Im gonna buy a 60mm Boost n fit it in a pod. Gonna speak to my scooby friends as japan is the land of grey interiors so they have grey pods i believe Quote Share this post Link to post Share on other sites
G60 0 Posted May 27, 2003 ya, i'm goin with summit for a/f as well... problem is that my current boost gauge is autometer... so i think i'll buy an autometer volts to match that on the a-pillar and stick the a/f somewhere else... not too sure where yet tho! i'd like to have it in a discrete spot so its not blinkin me to death all night.. but i want it visable when i'm comin up to redline so i can make sure its not goin lean. do you find that the summit pisses you off with the flashin lights? Quote Share this post Link to post Share on other sites
G60Jet 1 Posted May 27, 2003 G60, Do you have thsoe silly american seat belt thing in your motor? Quote Share this post Link to post Share on other sites
BigTartanJudge 0 Posted May 27, 2003 Lanny, Hopefully going to have combination oil temperature and pressure (2 in 1), boost, air / fuel ratio and inlet temp gauges, hence boost and air / fuel in A-pillar pod and others in centre console, SCOTCORRADOG6O Quote Share this post Link to post Share on other sites
Hans G60.nl 0 Posted May 28, 2003 at the vag concern you can order a panel for under the ashtray in which are holes for 52mm instruments.. every brand fits in there and the panel costs about 10 euro. :lol: Quote Share this post Link to post Share on other sites
Banana Man 0 Posted May 28, 2003 Hans thats the VDO gauge panel which you are talking about but as of last october it was discontinued at main dealers and there aren't any left at any dealerships in the uk now so the only other alternative is make your own now!!! :D Quote Share this post Link to post Share on other sites
Hans G60.nl 0 Posted May 28, 2003 no no , this is an original vw part.... in the netherlands you can still buy them... i'll look if i can find the article number here if you like.. you can allso buy pillar mounts from autostyle: http://www.autostyle.nl Quote Share this post Link to post Share on other sites
VR6 0 Posted May 28, 2003 Yeah but I think that whilst both LHD and RHD version are obsolete, you might still be able to get the LHD version from dealers stock. Quote Share this post Link to post Share on other sites
Hans G60.nl 0 Posted May 28, 2003 are you sure that this panel is different in lhd or rhd ???? the space available seems symmetric (i hope you understand what i mean, my english is a bit poor) anyway... the panel that WAS in my corrado was built from a cassete holder with a plastic panel glued on and the cassette unit removed.. worked perfect, but i preferred the original look Quote Share this post Link to post Share on other sites
VR6 0 Posted May 28, 2003 Yeah I'm 90% certain that there is a different LHD and RHD part. I know what you mean though - you would've thought that the centre console would have remained the same whether or not it had a LHD or RHD dash. Quote Share this post Link to post Share on other sites
dubster82 0 Posted May 28, 2003 Yeah, they are definatly different, i have one in mine. Scot, You could always do an idea that i saw in Biggar at the weekend (well, the car park at least!) I Saw a G40 with its boost gauge nicely , Duct taped into the centre consle!!!!! Quote Share this post Link to post Share on other sites
Fat Tony 0 Posted June 1, 2003 HANS They are definately different as I got one from the US the guy said will fit no problems BS*(& But they still stock them for LHD http://www.neuspeed.com/catalog/6Lighti ... terior.pdf goto page 8 vdo section. Postage is a bit high thou Quote Share this post Link to post Share on other sites
G60Jet 1 Posted June 3, 2003 Fat Tony, Did you buy a LHD or RHD part? Quote Share this post Link to post Share on other sites
Fat Tony 0 Posted June 3, 2003 I bought both, LHD from the US said it would fit didnt returned it and cost me 40 bucks in postage :mad: Then got two RHD ones as I waited so long for the UK dealers to produce them Sold the other one on the forum for a fiver Cheers Quote Share this post Link to post Share on other sites
G60Jet 1 Posted June 3, 2003 Fat Tony, why wouldn't it fit? was it cos of the seat belt thing. would it fit the passenger side of your motor? Quote Share this post Link to post Share on other sites
dubster82 0 Posted June 3, 2003 G60Jet, I dont think they're talking about an A-pillar gauge pod..... Quote Share this post Link to post Share on other sites
