slot 0 Posted October 25, 2004 Has anyone ever replaced the dizzy cap on the vr ??? I removed the unit yesterday , but it doesn't look as easy as i thought !!! :roll: Is it a sealed unit ?? I wouldn't ask , but the lower part of the cap is crack and as i know from the past , water and ignition system's dont mix well !!! :) Quote Share this post Link to post Share on other sites
slot 0 Posted October 26, 2004 I take it , i'm the only person to atempt this ?? :lol: Quote Share this post Link to post Share on other sites
dav 0 Posted October 26, 2004 Its quite easy mate, just the same as changing any other dizzy cap. I got mine from GS&F as VW was out of stock. Just unclip it and remove the black cover from the actual cap (all will become apparent when you take the cap off) and place it on the new cap. The Black cover has all the numbers which correspond to which number HT lead needs to be plugged in so you can’t really go wrong. Put it all back together the same way you took it apart. Remember the little earth lead type thing that plugs in to the side of the cap. It’s also a good time to change the rota arm, if it’s the original it will be glued on. I removed the on my VR with a pair of mole grips. hope this helps. D. Quote Share this post Link to post Share on other sites
slot 0 Posted October 26, 2004 Does your look like this mate ??? :roll: Quote Share this post Link to post Share on other sites
vr6storm 0 Posted October 26, 2004 Does your look like this mate ??? :roll: looks suspicously like a coil-pack to me :wink: Quote Share this post Link to post Share on other sites
slot 0 Posted October 26, 2004 Is this not the dizzy cap then ??? :scratch: Quote Share this post Link to post Share on other sites
STORM 2 0 Posted October 26, 2004 :D :D :D coil pack :D :D :D tried to 'service' mine but youre right its all sealed Quote Share this post Link to post Share on other sites
dav 0 Posted October 27, 2004 That is indeed a coil pack, disregard my naff instructions :roll: Quote Share this post Link to post Share on other sites
theRuler 0 Posted October 27, 2004 It’s also a good time to change the rota arm, if it’s the original it will be glued on. I removed the on my VR with a pair of mole grips. did some vr's have a rotOR arm / dizzy? Quote Share this post Link to post Share on other sites
Henny 0 Posted October 27, 2004 yup... early VR6's had a dizzy, cap and rotor arm... Quote Share this post Link to post Share on other sites
