del68 0 Posted October 31, 2004 Couple of times today I got a beep from the dash when going round a round-a-bout. They were not particularly tight but I did take them faster than normal, 15-20mph. It's happened twice now, no other signs of anything being wrong just this beep as I turned right. Tried doing the same on a carpark going left and right but nothing. Confused :scratch: Quote Share this post Link to post Share on other sites
Jim 1 Posted October 31, 2004 Check your oil - that buzzer is the oil level warning noise, and the higher speed corner taking has caused the oil level to get low enough to trigger the alarm! Quote Share this post Link to post Share on other sites
VR6 0 Posted October 31, 2004 Be very careful if you're not sure what level the oil is at (as Jim says). Quote Share this post Link to post Share on other sites
del68 0 Posted October 31, 2004 Oil levelis fine. It was a beep not a buzz! Quote Share this post Link to post Share on other sites
VR6 0 Posted October 31, 2004 I can't think what else normally beeps :?: Quote Share this post Link to post Share on other sites
samm_cvr6 0 Posted October 31, 2004 had the same problem on mine, only happened when I took a corner and particularly roundabouts fairly quicky. But mine was low on oil so not sure if there is another explanation for you'r scenario, maybe just a computer malfunction? Quote Share this post Link to post Share on other sites
daves16v 1 Posted October 31, 2004 Jim was referring to the beep, he just called it a buzzer. Quote Share this post Link to post Share on other sites
del68 0 Posted October 31, 2004 Cheers chaps. Also just wen tthrough my recent service invoice. Bloody garage used Magnatec. I think that will explain it :oops: Quote Share this post Link to post Share on other sites
