rmn 0 Posted November 4, 2004 i am having a strange problem, its a water leak that has just started its coming from the outpit side of the charger, but it only happens when its hot, i have yet to do some stripping of the car and see what the problem is. i am just wondering if its a common fault, like the vr6 housing? Any help appreciated, i would love it to be simple, but i know it wont be :( thanks Quote Share this post Link to post Share on other sites
coolrado 0 Posted November 4, 2004 i am having a strange problem, its a water leak that has just started its coming from the outpit side of the charger, water coming out of the charger?? there is no water feed to the charger so the problem has to be before the charger or from the boost return check your oil for water contamination and water for oil contamination Quote Share this post Link to post Share on other sites
rmn 0 Posted November 4, 2004 no,. its the output side of the charger on the block, sorry Quote Share this post Link to post Share on other sites
coolrado 0 Posted November 4, 2004 do you mean the supercharger? i thought you meant it was actually coming from the charger from your description :lol: Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 4, 2004 Eh? *mod edit - deleted your quadruple post... - Henny* Quote Share this post Link to post Share on other sites
Henny 0 Posted November 4, 2004 sounds like the plastic flange on the front of the block to me... that's the common place for waterleaks, but it's also worth checking the waterhoses which connect to it too... 8) If it is the black plastic flange, then do the one on the right hand side of the head while you're changing it, else you'll have to do it not long after as the increased pressure will cause the seal in that one to leak! :roll: Quote Share this post Link to post Share on other sites
rmn 0 Posted November 4, 2004 Thanks Henny! Your car looked very well in the pvw feature Quote Share this post Link to post Share on other sites
Henny 0 Posted November 4, 2004 yeah, thanks 8) Shame it doesn't look quite so clever now... :( Have a look HERE and see if it's the same leak as I'm on about... 8) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 4, 2004 I think he means the water pump pipes... :roll: Quote Share this post Link to post Share on other sites
Henny 0 Posted November 5, 2004 Supercharged, Could be... [/hong kong phooey] Any feedback rmn? Quote Share this post Link to post Share on other sites
vwdubs 0 Posted November 5, 2004 If it is the picture Henny is showing ya make sure you get an extra blocking plug as the flanges now have 3 sender points. Quote Share this post Link to post Share on other sites
