cheesy
Couple Q's regards to g60 conversion
Switch below isv above fuel rail, what is it for?
Also i have fitted rallye block which have abs, i don't
How do i patch into inlet manifold for my brake servo? best place to do it?
What colour wires for Lambda Probe?
chris
that is the fan after run switch ...
get the specfic peice of hard pipe work from the inlet nanifold to the servo..
there is a offshoot of the loom with 4 wires in one of the is a shielded wire and one either red/white or voilet.
chris
dealer sells the pipe for around £30... The reaon that the Rallye has a different one is that it's LHD and doesn't have a servo! you may well be able to use your original pipe and valve, I can't remember where it comes from on the valver though...
cheers ian
