chrishill 0 Posted November 16, 2004 just had my c dropped 40mm and i'm running 16x7.5's. I was giving it a bit of stick around a round about....er...testing ;) and there was a nasty scrubbing noise so i backed off and stopped. basically the top edge of the tyre is catching the arch liner as the car leans over! am i safe to take them out? what sort of problems could i have? and with that done should i get the arches rolled too? didnt think i'd have to with that sort of drop but if i do....ah well! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted November 16, 2004 What offset are the wheels..? Quote Share this post Link to post Share on other sites
chrishill 0 Posted November 16, 2004 et35's, no spacers or anything, just had tracking and camber done too, tyres are 205/45/16's Quote Share this post Link to post Share on other sites
daves16v 1 Posted November 16, 2004 I've never taken inner liners out b4 but they are in there for a reason.............you're gonna get water, mud, crap etc high up into the inner wing area, all this = less protection and more corrosion. Sorry can't help with a solution. Quote Share this post Link to post Share on other sites
stevemac 0 Posted November 16, 2004 chrishill, you have any bumpstops fitted ? Quote Share this post Link to post Share on other sites
chrishill 0 Posted November 16, 2004 erm...no :oops: i forgot to get new ones and left them off in the end thinking it wouldnt make much difference Quote Share this post Link to post Share on other sites
stevemac 0 Posted November 16, 2004 Now you know the difference that they make. :shock: Quote Share this post Link to post Share on other sites
chrishill 0 Posted November 16, 2004 bah! back to the drawing board then...well...back to the jack with some new bumpstops! ta steve Quote Share this post Link to post Share on other sites
chrishill 0 Posted November 18, 2004 just a thought, the suspension rattles quite alot, could that be down to a lack bumpstops too? the sound makes me think the springs loose on the damper, at least thats what it 'sounds' like to my untrained amature ear! I got one of Euro car parts 'lowering' kits which is bilstein dampers and ventura springs. car looks great on them and the ride would be ok if it wasnt for the scrubbing and the rattles! :( any ideas? Quote Share this post Link to post Share on other sites
stevemac 0 Posted November 18, 2004 Did you renew the top mounts ? If not, then renew them when you fit the bumpstops. :wink: Everything on the front suspension legs is kept tightly together by the springs - except for the bearings in the top mounts. Other possibilities for your rattling - bottom ball joints, lower arm bushes, anti roll links & bushes Quote Share this post Link to post Share on other sites
daves16v 1 Posted November 18, 2004 stevemac, what do you get with the top mounts? Are the bearings in there? Quote Share this post Link to post Share on other sites
stevemac 0 Posted November 18, 2004 1.8-16v & G60 mounts have the bearings inside the mount. VR6 ones are separate. Not sure which type the 2.0-16v's have. VR6 mounts are much stronger & better design. Not just a straight swap for the G60 style mounts though - need to change the top spring mounting plate, top mount & bearing. Quote Share this post Link to post Share on other sites
chrishill 0 Posted November 18, 2004 top mounts were left as they were, to be quite honest i should have learned my lesson by now, i bought the suspension without thinking about the bumpstops and top mounts, then when we got them off and realised they were shot, I though nah the hell with it, it'll be ok! obviously not! cheers steve, i'll get the top mounts changed and get the bumpstops on and fingers crossed that'll cure it! Quote Share this post Link to post Share on other sites
