clayman
cold start problem?
1990 G60 runs great when warm , but will not start cold? Replaced plugs and fuel filter. Nothing obvious. Any suggestions on what to check next?
could be. The only way to start is to physically block off the air flow to the air box to create an enriched supply. Does the blue temp feed that type of signal to the CPU?Thanks
i had same problem here,
and when i replaced famous blue temp send everything worked fine,
though still when its cold i have to ignite 2 or 3 times before everything starts to work fine
usualy on first start engine just shuts down after 5-10 sec
i suppose this is more-less usual
