mariovr6
gearbox tool
hello
can someone please tell me what the tool i need to put gearbox oil in??
if im looking at the correct bolt it looks like its a reverse of a normal bolt?
what size is it ? where can i get it from?
also been told on here that i should try redex oil in the gearbox? is it called redex gearbox oil??? cant find it in the shops?
It's a 17mm allen key.
The oil you are looking for is REDLINE. REDEX is a petrol treatment.
Gavin
You can get the 17mm allen key from Halfords- think they call it a gear oil key or something like that. I used Slick 50 gearbox treatment with 2 bottles of Castrol SMX-S, which you can get from larger Halfords. Check out the how-to guide for this- it's very helpful :wink:
By the way, some peolpe don't recommend using the Slick-50 treatment, although my gear change has never been better :D If I was going to do it now, don't think I'd use it.
It's alright in the Gearbox as there are no oilways for it to block!
cheers guys thats helped loads!!!!
all i need now is a day off in daylight n im on my way!!!!!!
o yeah i see some stuff by a company could LUCAS its american they make engine treatments too any got anything to say about it?
