Rossco
Coils
Does anyone know if i can use a 16v coil for my G60, are they the same or do i need the G60 one?
Cheers
Ross
Prolly a different part number but I don't see why it wouldn't work. You can't use points coils with electronic ignition but assuming they are physically the same and have the same connections it would work.
ETKA check would say for sure.
Gavin
the g60 is heavier than the 16v... only by about 100kgs max, i could get correct figures if needed. I would imagine the units wold be the same just have different dampening properties....?
