markmcie
Gear stick slips into reverse
Hey all,
There must be a bush or something worn on my gear shift. I still have to push the stick down to engage reverse but if I push the stick to the left with a little effort it will slip into reverse. Its annoying when changing from 1st to 2nd and it gets caught. I cant see anything worn but it must be a problem for some other corrado's.
I've sorted this on mk2 Golf's before but not on a cable shift. Anyone got any tips ??
Mark
You need to do some adjusting I suspect. Check that the lever is held on with a clip on the shaft that runs across the car. Common for them to disappear.
Gavin
the clip came off the lever on mine and caused the same sort of problems. lift off the gaitor and check for this clip
