Bournemouth James
Best mods for a g60 engine for around
charger rebuild, pulley and chip to handle the higher boost. thats gotta be £1000 if not more. with the amount of boost generated at high rpms with a 65mm (should be over 18psi on a healthy freshly rebuilt charger..if ported somewhat) you need to up the fueling to at least a 3.5bar fuel pressure regulator, and probably 30# injectors.
if i were you with £1000 i'd spend it all on the charger and save the extra couple hundred for maintenace.. or put it toward the next stage of mods.. pulley, chip, fpr, injectors, cam...lots of power to be made there.
K&N panel filter >£30
Fast road pads (no point in going fast if you can't stop faster) £40ish i think
Charger rebuild £600 max depending how far you go
new plugs
plug leads
SNS CHIP
Fuel pressure regulator
that should see £1000 or so
