markcorrado1
Audi/Passat 5x112 Hub Front/Rear Connversion???
Golf MK5 and Passat 3B.
Wanting to fit Mercedes rims are you?
I got these Audi/Merc wheels for an amazing $450 :D
Enkei 3 peice, 18x8, ETA 37mm, 5x112
Now I NEED to make them fit 8)
Have you considered having yours drilled?
I would redrill my front hubs but my only problem is the rear rotor, I don't want to keep redrilling rotors everytime I buy new ones. If I could find out what VAG 5x112 rear rotor could fit a corrado then I would drill the front hubs in a heart beat. I'm also converting my front brake setup to Audi TT specs, so if I go 5x112 would I be able to use the Audi A8 front rotors which are 12.3 like the TT???
markcorrado1, I`ve got a set of wheel adaptors which allow you to fit 5x112 wheels onto 5x100 hubs.You can have them if you are interested.(coming to Florida in May so could even deliver them :lol: )
Will take payment in dollars too :lol:
What's the size/brand/hub centric of the adapters and how much?
I would use H&R adapters but I think it create a problem with pushing out the wheels to much. the wheels are 37mm and the smallest H&R adapters are 20mm :(
Im wanting to fit Aero II's to my VRr.
Is having your hubs drilled a costly job?
Is it legal?
Is it safe!?
Fitting 3b rear brakes is probably major work, the stub axles are totally different.
It would be great if someone could get some pics up to guage the amount of work.
