Blue_Joe 0 Posted January 14, 2005 Hi All Well once again (this is getting all to often!!!) I've gone and spent another small fortune on my G60 by investing in some FK Silverline Plus Coilovers (Konigsports, but made of Stainless Steel!) Here's my question, it's been suggested I get some uprated top mounts as apparentkly coilovers chew through standard mounts at an alarming rate. Admittedly this sounds like a fairly good idea as I've replaced all but the rear axle mounts (to maintain the passive steering!) with poly bushes so seems like the next step. So any advice on what to get, price and where from????? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 14, 2005 Fit standard VR6 or Bonrath uprated G60 poly ones. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 14, 2005 Yeah VR6/Mk3 ones are cheaper and stronger Quote Share this post Link to post Share on other sites
stevemac 0 Posted January 14, 2005 VR6 ones get my vote Quote Share this post Link to post Share on other sites
billinjah 0 Posted January 15, 2005 who does the bonrath ones? Quote Share this post Link to post Share on other sites
g60pops 0 Posted January 15, 2005 If you can get the blue bonrath ones go for those. Quote Share this post Link to post Share on other sites
Geo 0 Posted January 16, 2005 What's different about the VR6 ones? Will they fit a mk2 golf? The ones in my golf are shot and I'm putting in new shocks next week so am wondering which top mounts to go for. (sorry for the thread hijack by the way) Quote Share this post Link to post Share on other sites
stevemac 0 Posted January 16, 2005 The VR6 ones are a slightly different, much improved design & have seperate bearings. You're also likely to need the VR "top spring mounting plates" as these have a recessed bearing seat. Yes - they should also fit a MK2 Golf.. :wink: Quote Share this post Link to post Share on other sites
rmn 0 Posted January 26, 2005 anyone know where to get bonrath ones? Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted January 26, 2005 It turns out that you can't use the bonrath ones or similar with coilovers as they move about and knock alot. You have to use the standard ones. Just make sure you buy the proper VAG ones only available from VAG as they are stronger Quote Share this post Link to post Share on other sites
Bally 0 Posted January 26, 2005 I need to replace myn, they are knocking alot! Quote Share this post Link to post Share on other sites
