davidwatsonok 0 Posted January 24, 2005 Does anyone know a supplier of the above part ? GSF have none, nor Europarts, and I'm told VW have no stock either :( Thanks for any help. Quote Share this post Link to post Share on other sites
fla 9 Posted January 24, 2005 Does this mean you will get no heat in the car if used? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted January 24, 2005 They are not required for cars built after 92ish - all the later heater matrices have this feature built-in. Quote Share this post Link to post Share on other sites
h100vw 0 Posted January 24, 2005 Check that your local dealer cannot find one in another dealer. I was told last week that VW are trying to get more of these valves made. A reliable scource at VW. The bypass valves stop the matrix from blowing. They do fail and I have had it happen to me. You get hardly any heat in the cabin due to really poor flow thru the matrix. New valves sort it out. You can remove the valves and join up the pipes again. Thing is if 5 year old matrixes were blowing, then one more than 10 years old must be more likely to go. A new improved matrix is about the same money as a valve kit. A swine to fit but if you can't get the valves then it's your only option IMO. You can then bin the valves anyway. Gavin Quote Share this post Link to post Share on other sites
