Bora Bora 0 Posted January 24, 2005 ...to my valver. Noticed it starts better, runs better but according to the MFA I am generally getting about 5 miles less to the gallon! Any advice??? Quote Share this post Link to post Share on other sites
CoxyLaad 0 Posted January 24, 2005 put the old one back on lol Quote Share this post Link to post Share on other sites
aide 0 Posted January 25, 2005 if you did it yourself, have you checked the control pressure and mixture - as these will need to be set up too. re the MFA readings, they're usually pretty balls anyway! Quote Share this post Link to post Share on other sites
Henny 0 Posted January 25, 2005 check that you've not knocked one of the vacuum pipes off the bottom of the airbox. Also, have you had the CO emissions setup? The new metering head won't be setup to run efficiently with the rest of your injection system so may be running rich... 8) Quote Share this post Link to post Share on other sites
