borderair 0 Posted January 26, 2005 hello - does anybody know the poly-vee drivebelt size that you use when fitting a 68mm pulley - i am guessing that it will be shorter than the 6PK1650 original ? Quote Share this post Link to post Share on other sites
h100vw 0 Posted January 26, 2005 I am still running a std belt on my Passat, no evidence of slipping to my knowledge. Contact G-Werks. Darren will sell you one if a shorter one is needed. Gavin Quote Share this post Link to post Share on other sites
borderair 0 Posted January 26, 2005 Thanks for the answer - however the std belt is not accepteble as the tensioner is to far down its travel. Also belts should be changed approx every 10K when running a charger, so if someone knows the correct size it would be useful. Quote Share this post Link to post Share on other sites
gibber 0 Posted January 26, 2005 Hehe someone doubting Gavin! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 26, 2005 Yep, you need a shorter belt when fitting a smaller pulley, look on the G-werks site or info, Darren sells them for about £20 Quote Share this post Link to post Share on other sites
W3RKD 0 Posted January 26, 2005 gates 68416 is what u are needing :D Quote Share this post Link to post Share on other sites
