VW ASSASSIN 0 Posted February 1, 2005 My oil light keeps coming on and beeping wen im driving even though i have enough oil in the engine Can anyone help Cheers Quote Share this post Link to post Share on other sites
stevemac 0 Posted February 1, 2005 Either you have a broken oil pressure switch, faulty wiring or your oil pump is dead. Find out exactly what is wrong before driving the car. You should be able to bridge the oil pressure switch to check it's functionality. Quote Share this post Link to post Share on other sites
h100vw 0 Posted February 1, 2005 Does it remain off at tickover and come on at 2500 revs? That would point to the high pressure switch. You need to have it checked with a pressure gauge really. I would have the sump off regardless to make sure the pump pickup isn't blocked, this is a common cause of this problem if there isn't a switch issue. Gavin Quote Share this post Link to post Share on other sites
VW ASSASSIN 0 Posted February 1, 2005 it comes on now and then its abit tempermental Quote Share this post Link to post Share on other sites
