fla 9 Posted February 8, 2005 Gentlemen, Seems like an obvious one but my version of VAGCOM doesnt allow me to delete the error codes when you press the "clear codes" button. Its registered through RossTech, but the only ones I can remove are the ones shown in red after the scan. Something I'm doing wrong? Thanks Quote Share this post Link to post Share on other sites
kebabman 0 Posted February 8, 2005 That's strange indeed mate, I've used version 311.6 and the latest non-beta (4.06 I think) and on both, I just clicked auto-scan, saved the codes to note pad and clicked the 'Clear Codes' button. That did it for me, does it give you any error messages or just exit the screen? Quote Share this post Link to post Share on other sites
fla 9 Posted February 15, 2005 Certainly on Autoscan it doesn't allow me to clea the codes. When I scan each unit in turn eg brakes, transmission, these can then be deleted. Just a point, after clearing the codes, what kind of a drive is needed to check if they appear again? I cleared all the codes, took it for a short drive and then rescanned. Result: no fault codes. Now does that mean i need to go for a long hard drive, or, if faults are present, should they appear immediately? Quote Share this post Link to post Share on other sites
