g60Dazzaman 0 Posted February 10, 2005 There is too much pressure in my coolant system, Stevemac told me that their is probably a block in the system somewhere, does anyone know any sort of product i can stick in the system to free it up? Quote Share this post Link to post Share on other sites
willwoll100 0 Posted February 10, 2005 Try flushing out the system as if their's a blockage this is the best thing to do and pop some lovely fresh coolant in :D Quote Share this post Link to post Share on other sites
g60Dazzaman 0 Posted February 10, 2005 Yes but what to flush it out with? Is it a case where i need to take the water system to bits or is their a product available that will free up a blockage? Quote Share this post Link to post Share on other sites
willwoll100 0 Posted February 10, 2005 Flush it out with water from a hose, you can get a chemical to use first but not sure what it's called. The blockage in cooling systems generally appear in the radiator so just back flush it to see what appears. Quote Share this post Link to post Share on other sites
bustwell 0 Posted February 10, 2005 Flush through with loads of clean water. If that fails to unblock then its time to start removing hoses etc. Quote Share this post Link to post Share on other sites
Funkster 0 Posted February 11, 2005 I have used Wynn's cooling system flush on all-iron engines with good results. However, I haven't tried it on lumps with alloy heads... anyone know if it's a really bad idea? Cheers, -- Olly Quote Share this post Link to post Share on other sites
davidwort 0 Posted February 11, 2005 I have used Wynn's cooling system flush on all-iron engines with good results. However, I haven't tried it on lumps with alloy heads... anyone know if it's a really bad idea? Cheers, -- Olly I think you could dislodge some muck only for it to get stuck somewhere more critical, I don't like oil or coolant flush chemicals for this reason on old engines, fine if you regularly use it on a newish one. David. Quote Share this post Link to post Share on other sites
Funkster 0 Posted February 11, 2005 Fair point, although in the engine I used it on it doesn't just break big chunks free - it breaks the bits down to a size where they probably wouldn't get stuck anywhere. This seems like a better idea than just trying to move stuff around with water? I'm just a bit paranoid about the chemicals attacking the head. -- Olly Quote Share this post Link to post Share on other sites
