kongo127
Higher Voltage Ignition Coil
The spark is used to ignite the air/fuel mixture. Some high revving engines have used 2 sparkplugs because the mixture burns at a pretty uniform rate. Set the flame burning from 2 places would mean a complete burn in less time. This also works with big combustion chambers.
Have a bigger more powerful spark would have little difference with regards to power output.
Some big turbo motors running loads of boost have been known to 'blow' the spark out. I can't imagine how.
I believe if the G60 needed a better coil, VW would have fitted it at the factory.
If the std ignition system has no faults and the plugs are gapped correctly I doubt very much whether you could get more performance.
Gavin
