Borat
Help....Caliper Spring (2.0 16V)
:( Afternoon guys. I have a problem that i really need to sort out ASAP. My drivers side rear handbrake spring on the caliper has lost its tension, and therefore is causing the handbrake to remain on partially...enough to make the wheels smoke. As i only need the spring where could i get one from as VW say i have to buy a whole new caliper at £90 just for that spring.
If anybody has or knows of a good spares place i could phone please help.
Kind regards
Chris :oops:
Are you 100% sure it's the spring, it's normally a seized caliper when that happens...
Ford sell a similar spring off a Granada (scorpio) which is uprated and fits straight on... I only know this 'cos it was one of the bodges for avoiding seized calipers I read about when I first got a Corrado back in '98...
nice one dude. I spoke to a breaker earlier today and he said the same thing but you can move the caliper arm ok. its a little stiff but the spring is not quite pulling it back far enough. The caliper arm moves the full range but not with the spring on.
I will try :lol:
I tried to get the Granada springs a few years ago from Ford but the part is discontinued. Try freeing the lever off by taking the caliper off and cycling the lever over and over. I did this and it worked fine. Otherwise save up and get some Mk4 rear calipers as they have this mechanism internal and therefore dont sieze as easily.
do the mk4 go straight on without any mods? but i will try the unseizing process. thanks alot guys :lol:
well i managed to get some of the springs off the granada and it fits on and the brakes are back to normal. thanks for that coullstar that saved me a packet, considering i half inched them. :D
