PeterMunns
Quick question mark2 golf suspension on C ??
My friend is selling his suspension its G-Max lowers by 80mm Is less than a year old still with 2year warrenty
He has a Mark2 Golf ryder 1.6
Will it fit my Corrado 16v
I'm pretty sure the rear suspension is all Mk2 Golf, but the front is Mk2 Passat, so might not work.
its the other way about on the valver and G60 IIRC
:lol: They like to keep it simple :roll:
Either way, half of the suspension will fit, half of it won't...
Yes the layout and mount is the same its only the damping and spring ratio is different
Mk2 16v rear shocks are the same as corrado rates and all (but not vr6)but the corrado fronts are shorter stroke ,,the shocks you are talking will fit on ok ,,just check the two fronts beside each other if they are the same your good to go ,,, I am not fussed on G max ,,,buy boge
turbo gas shocks £33.50 each front part number 62544042 and £28 for rears part /n 62544019 real good road shock would be better than g max
i would say get them from euro £54.99 for a lower spring kit as well 40mm
