G60Speed 0 Posted March 21, 2005 Just in the process of replacing the con-rod bearings in my G60, but i dont have a manual with torque settings. Anyone know how tight the cap bolts should be?? Many Thanks!! Quote Share this post Link to post Share on other sites
G60Speed 0 Posted March 21, 2005 Dont worry people.. found it on a haynes pdf download If anyone else needs some tech specs.. Quote Share this post Link to post Share on other sites
steveo29 0 Posted March 21, 2005 what were the bearings like?? my number 1 bearings were shot to hell Quote Share this post Link to post Share on other sites
G60Speed 0 Posted March 21, 2005 Needed replacing, the bearing material on no.1 was just getting down to the backing.. was a lot easier than i thought , once I had got the obligatory 2 x awkward sump bolts out (by the gearbox)! Only hope that when I come to fire it back up, the knocking i had before wasn't the main bearings..? Quote Share this post Link to post Share on other sites
steveo29 0 Posted March 21, 2005 was it a rattle at 3k...light throttle?? Quote Share this post Link to post Share on other sites
Andy D 0 Posted March 21, 2005 Torque settings PG Small end bearing caps 65nm with lock tight Big end bearing caps 30nm + 90° times 2 with lock tight Crank pulley *80nm with lock tight Quote Share this post Link to post Share on other sites
