Walesy
transponder key???
just a quickie...i ant to have a spare key cut for my 1995 8v...does anyone know if the key has a transponder???
Take the cowling off the steering column, if its got a txpndr there will be a loop aerial thingy around the lock.
Failing that VW should be able to tell you based on the chassis number. If it does have one the keys are about £15 and you will probably get hit for half an hours labour to programme it. Although I believe you can program them with VAGCOM.
Gavin
