kevin
dashboard gremlings
hi just transplanted a g60 into my old valver and everything works exept the dash board,so i sourced a digi clock set and wiring loom and after installing this nothing on the dash then worked,tryed a few searches on here and came across a document in german that i had translated and i now have 80% of the dash working :lol:
the last 20% is where im left and was wondering if anyone knows what i still need to do . only the temp gauge and fuel gauge are not working,this is the only things needing to get done,
if i plug my valver clocks in the fuel gauge works on them .
so i think its only a wire needs changing over or something simple.
any help gratefully recived.
regards kevin
sounds like a missing earth...
well done mate!
i´m going for a digital odometer aswell, it´s good to know that it really works!
by the way... did you have the gearbox sender, or needed to get one?
how much does VW quote for them?
well done mate!
yes mate you need the digital gearbox sender,if you pm me your email address ill send you the document showing you how this is done.its not to hard.been working on it today and now the fuel gauge works aswell only the water temp and fan afterrun to sort out,anyone got any ideas
regards kevin
