G60Speed 0 Posted March 28, 2005 Just started the car back up, after having new conrod bearings. The car will start, and tick over quite happily, but as soon as I go to rev it, there is a delay of 3-4 seconds, before the revs pick up.. any ideas? Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted March 28, 2005 Need a bit more info mate,What model?G60,1800,2000cc16v?. Who did the work,you or garage mechanic? What cond. is your engine in,did you change the fuel filter?,cam timing might be a tooth out, What else was done to the engine? Cheers,Andrew. Quote Share this post Link to post Share on other sites
G60Speed 0 Posted March 29, 2005 G60 1800cc All I have done, is change the conrod bearings. the car was running normally before, I have changed oil,plugs and leads (including the HT lead to distributor). the petrol filter has not been changed.. might try that i think? Quote Share this post Link to post Share on other sites
Henny 0 Posted March 30, 2005 check the vacuum hose from the back of the throttle body to the ECU. This needs to be exactly 1m long and MUST be in good condition. If it's not, the ECU won't know what the hell is going on and so won't be able to tell the engine what to do properly. Quote Share this post Link to post Share on other sites
G60Speed 0 Posted March 30, 2005 Gonna have a look, will post back with results thanks Quote Share this post Link to post Share on other sites
STORM 2 0 Posted March 30, 2005 coolant temp and cam position sensors - both cheap to replace and worth the gamble Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted March 30, 2005 G60's don't have cam sensors mate. Check Fuel pressure with a fuel pressure gauge. Quote Share this post Link to post Share on other sites
