Red_16v 0 Posted April 2, 2005 hi everyone i was just wondering if anyone who's fitted a 50mm inlet or just changed their's knows how to go about removing the actual injectors from the lower half of the manifold. The manifold its self is off but the injectors are rounded so i can use a socket or spanner to remove. any ideas? Quote Share this post Link to post Share on other sites
randal 0 Posted April 2, 2005 Mole grips? Sounds pretty terminal if they're rounded. :( Quote Share this post Link to post Share on other sites
Red_16v 0 Posted April 2, 2005 sorry, what i meant is the actual injector part that needs to indo is circular (i.e. its made like that). its like this in a haynes manual but doesnt show how to get them out. any other ides? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 2, 2005 On the 1800, the injectors simply pull out. Best done when the engine is hot and they come out a lot easier. Just pull on the rigid fuel line and out they come. I would replace all the seals, plastic sleeves and brass inserts whilst you're there. 4 x brass inserts 4 x insert seals (black) 4 x upper injector seals (green) 4 x lower injector seals (black) 4 x plastic sleeves (orange) Quote Share this post Link to post Share on other sites
flusted 0 Posted April 2, 2005 As kev says,just give em a good tug Quote Share this post Link to post Share on other sites
Red_16v 0 Posted April 3, 2005 thanks for all the help. a quick call to 16VG60 cleared things up though. i can get the injectors out but the new manifold doesnt have the brass inserts. i'll pop down to the local VW place to get the parts in the week. Quote Share this post Link to post Share on other sites
h100vw 0 Posted April 3, 2005 Red, the inserts screw out of the inlet manifold. You need a big old allen key, 10 or 12 mm. If the old ones come out no need for new ones. Not all those inserts are brass though, some are plastic and very brittle. I'd definately use new O rings on the injectors though. Snap on do a tool to pull the injectors without risking the pipework. Only cheap so I would advise buying one. The search has failed me though after 15 mins I have given up. Can't find it on the Snap on site either, it's in an obscure category. Gavin Quote Share this post Link to post Share on other sites
