VEEDUBBED
2000cc 9A G60-16v...
Hello all,
I'm almost finished with my latest
project engine a 2000cc 9A 16v corrado
motor equipped with a G-charger.
A few things i noticed while building up
the engine:
The 9A's inlet cam is identical to a 1800cc
golf/corrado 16v's cam,regardless of year
i got the impression that the 'KR's inlet had more
lift?,not so...
The 9A's oil pump is identical to a 1800 G60
oil pump,same part numbers.
The 9A's ISV is the same as an 'ABV' VR6's one.
If i see anything else worthy,i'll post it up.
that is puley central! Looks really good - always liek to see 16v g60's
What sort of pistons did u use/how did you lower the compresion ratio?
I have a 2.0l 16v and i'm keen to get more bhp, i was originally considering the 1.8T conversion, how does the G60 conversion compare, is itr alot cheaper/ easier to do?
I would say not, IMO. I've looked into both conversions, and the 1.8T conversion appears to be a lot easier as no real modifications to the engine is necessary, but the conversion to G60 on a 16v, 9A engine is a lot more involved, with compression ratio changes etc etc etc.....
Just my 2p's worth though
Very nice work!!! Great project!! It would be great to see more details: what modifications was done to engine (pistons, etc), what other parts did you need to make this modification?
