Blown
Miscellaneous terminals?
Anyone have a clue as to what these should be attached to?
I think the larger one was off the distributor shroud-which no longer exists-but I have no idea about the smaller one?
Blue/white is a redundant wire that feeds the oil pressure gauge if factory fitted. The green/black is for the oil temp sender.
Gavin
Gauge eh? Would this be similar for a 16v? I've got random terminals by my oil cooler and near the ISV too - these the same then?
ta
randal
The blue white wire goes into the fusebox but without the gauges fitted stops there. You could find out which plug it comes out in but then it would be a big hassle to use it. I'd just run a fresh wire in.
The 16V has that wrie too.
Gavin
