RobW 0 Posted April 8, 2005 got a g60...stage 4 charger, 68 pulley, sns5 chip, drilled a. box, stainless zorst. What next for the best gains pound for pound. Do I whack a piper cam in (or the like)? Intercooler? This boost return thing? 4 branch? Whats the general feel. Also got it on some weitec coilover adjustables...thinking about adding arb's...good combination??? Quote Share this post Link to post Share on other sites
samm_cvr6 0 Posted April 8, 2005 hmm, I think you want to make the flow and cooling optimum first so yea, maybe a 4 branch manifold and flowed head. I'm no expert on g60's tho. I know stevemac is doing a bit of a project on his so maybe he can enlighten you. Quote Share this post Link to post Share on other sites
W3RKD 0 Posted April 8, 2005 intercooler every time... Quote Share this post Link to post Share on other sites
carpoid 0 Posted April 8, 2005 Red tops, 3.5 bar FPR Quote Share this post Link to post Share on other sites
stevemac 0 Posted April 8, 2005 Fitting a cam to a G60 will usually not yeild much in the way of power - it will just move the max torque further up the rev range. I agree with Daz - front mount cooler is the next thing to do. Quote Share this post Link to post Share on other sites
Dubcharged 0 Posted April 8, 2005 Nice FMIC will be the best thing. You could remove the boost return anyway since you only need a couple of cheap parts ie breather filter and blanking plate. Quote Share this post Link to post Share on other sites
Riley 0 Posted April 8, 2005 i understand that the fmic is good through being able to have a more dense air in the intake,but what are the actual gains? just interested in the difference to be had from simply? running a front mount. cheers,neil. :) Quote Share this post Link to post Share on other sites
stevemac 0 Posted April 10, 2005 just interested in the difference to be had from simply? running a front mount. cheers,neil. :) The difference on cold winter days won't be nearly as noticable as it will be on a hot summers day. Standard G60 cooler is just too small & doesn't get enough air flow to cool the intake temperature very well. The cooler the air, the higher the oxygen content of the air. Engines only burn the oxygen content & consequently more oxygen = more power, therefore colder air = more power. Quote Share this post Link to post Share on other sites
Neil VR6 0 Posted April 10, 2005 Also a ported exhaust manifold and stainless downpipe will help enormously. Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted April 10, 2005 After an intercooler. How about toothed belt or aquamist? :-) Quote Share this post Link to post Share on other sites
potatonet 0 Posted April 10, 2005 A/C delete..... RSR outlet.... New Bright Green Tops, 42lb.... either 3.5 FPR or adjustable 4bar....spark plug wires.... FMIC..... 65mm pulley.... ISV reroute/delete.... blanking plate.... eurosport or BBM intercooler tubes.... ported throttle body.... exhaust header.... chopped intake manifold (EIPtuning.com).... and you could cam it.... I think I listed em all that u dont have... dunno about the suspension sorry Quote Share this post Link to post Share on other sites
potatonet 0 Posted April 10, 2005 my neuspeed cam didnt do much for me, transition between 5 and 6k rpms is fast as H3LL tho Quote Share this post Link to post Share on other sites
