Dixxy
Power Boost valves
Just had a little browse on the old NET and found FSE Power Boost Valves.
Here's the description...
"An FSE Power Boost Valve replaces the standard fuel pressure regulator fitted to the engine. On acceleration the Power Boost Valve will increase the fuel pressure in the fuel rail at 1.7 times the standard rate. This enriches the mixture under acceleration which will improve the driveability of your vehicle."
Has anyone tried one of these? whats the verdict? naff product?
What do you want to fit it on?
On a G60 your money would be better spent on a chip and pulley assuming the charger is fit enough.
Don't think of it as a cure all. Replacing plugs, cap and rotor and getting your car set up right would be another way of spending the money.
Gavin
