junkie
Digi-lag
Can any1 explain digi-lag please???
Is it the SNS chips that overcome this and if so how
do they cure the problem??
Are they a 1 chip fits all like Jabba 1's cos heard people
sayin they over fuel?
Surely only way to go is have a custom re-map but does this
still cure digi-lag??
Think its something to do with the ECU delaying fueling or
something, somebody correct me if im wrong??????
Just what i heard!!
jimsG60- cheers for that think i get the jist of it.
Just read about a new stage they do 5.5 whats the difference??
Are these custom maps but still cure the digilag,as can see def need custom??
SNS chips are the only chips to incorporate the No-Lag coding. It's relatively simple as to how it works, it's the coding of it that was the tricky bit... the map is the same as any other chip and so can be re-written without destroying the no-lag code... ;)
IIRC 5.5 is for the red-top injectors but doesn't need the 3.5bar FPR like the earlier stage 5 chips did...
I had my SNS stage 5 no-lag chip re-mapped to keep the no-lag but to have the map corrected so that it's spot on for my 1940cc G60 engine. Give Wayne Schofield a ring over at Chipwizards... He's done a few SNS remaps now and is bloody good! 8)
if i order am sns chip how would i adjust the co pot daz @ gwerks says he can supply a chip to my spec/set up but id need to adjust the co pot can i do this at home or do i need a garage with a wide band?
yeah i was talking to him and he said you 'just' need to adjust the co pot wasnt til after i got off the phone i realised i had no idea how to do this!!
