chris g 0 Posted May 10, 2005 Hi, my 2.0 16v is smoking a little on start up. Its a white, steam like smoke (No its not just condensation before you ask!) and it only does it when I first start it in the mornings or when its been stood for hours. I've not noticed it at any other time and was wondering what it might be, Could it be valve stem oil seals? if so is it an easy job to do? Does it involve removing the head? Cheers Chris Quote Share this post Link to post Share on other sites
vr6storm 0 Posted May 10, 2005 could be the start of a head gasket.....as it'll be water/coolant burning as opposed to oil which would be a blue haze white = water/coolant blue = oil black = fuel/carbon Quote Share this post Link to post Share on other sites
chris g 0 Posted May 10, 2005 I am pretty sure its oil, a very small amount of burning oil gives a white/grey smoke. Its definately not using/burning/loosing any coolant though, i'm sure of that. Quote Share this post Link to post Share on other sites
vr6storm 0 Posted May 10, 2005 is it using oil then? Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted May 10, 2005 if you sit for a while , like at traffic lights does it smoke as you pull away ? does sound like valve seals , Quote Share this post Link to post Share on other sites
chris g 0 Posted May 10, 2005 Yes its using some oil, but its not got any leaks anywhere Quote Share this post Link to post Share on other sites
h100vw 0 Posted May 10, 2005 It is unlikely that cahnaging the stem seals will fix it for long. If the guides are worn it'll not take the valves long to do the new seals. Best to have new exhaust guides fitted as a minimum if you take the head off. Probably about a tenner a guide to supply and fit. Gavin Quote Share this post Link to post Share on other sites
