junkie
FK v KW
Currently running Spax PSX lowered 60mm, not too bad but think under hard cornering a bit pants, plus general riding ok.
Basically would i improve my cornering on coilovers and if so which are better??
Also running Neuspeed anti-roll bars F+R think 25mm. Back end tends to let go a bit too eagerly sometimes, would my anti-roll bar need adjusting out back?
If you are able to soften teh rear ARB it will improve the situation. Most ARBs make a car twitchier at the limit, especially in the wet. My mk1 was very hard to drive quick in the wet. It would grip and grip and then see you spin. Std ARBs are much more progressive in nature.
Gavin
Well currently on medium setting, will change to softest.
Still wanna go coilovers as well which would you recommend?
Sorry, I don't do coilovers. Too expensive and too much trouble for me. Having had AVOs.
I would be happy fitting any Weitec gear though.
Gavin
