StormVR6
Beaten by a bloody Golf...????????????
Yes my ongoing problem of power loss is still ongoing, and today was the final straw. After having some gimp up my ar*e in a Golf V5 I finally approached a roundabout leading onto a dual-carriageway, well the Golf had done the obvious and started to boot it pass me and I thought sod off, well I thought it but it didn't happen! I used to eat V5's alive!!
I drained the engine of about half a litre of oil just to get it down to the MAX level due to Stealth being overzealous with the oil can, but am I right in thinking the CAT could be ruined from the overfill because there are still no faults on the VAG-COM and I am now running out of ideas.
Please help people before I buy an Austin Allegro and stick a stage 5 turbo on it for a laugh!
Cheers
MB
yep overfilled oil level can knacker the cat,id say only over a longish period though?
neil. :)
Right OK, cheers mate that confirms my thoughts and I would think 7 weeks is long enough to knacker it!
Right now if the CAT is buggered how much power decrease do we think this might cause?
The reason I'm starting to get so peeved over this is because only 7 weeks ago I paid out over £2000 on the C and it repays me with performance drops entitling bloody Golf's to cane it past me!
Oh if only I could quench the love affair I have for this headache of a car I would gladly give it away.
Right now if the CAT is buggered how much power decrease do we think this might cause?.
ive seen other motors not run at all due to the cat breaking up and blocking itself m8 :roll: and its meant a new cat each time.
im not totally sure what effect oil has on them,i think they just get blocked?
dont know what i can suggest really,can anyone help further?
hope you sort it m8,neil.
Stealth overzealous with oil, that doesn’t sound like them. Who at Stealth did the work ??
Id say 7 weeks is more than plenty of time to screw up the CAT but cant say how much power would be lost sorry :(
Does a knackered cat mean a more restrictive cat? I'm not convinced thats your problem, half a litre of oil surely can't knacker a cat. I'd have thought you would need much more. The only real way to be sure is to get it on a rolling road and see if its producing the power it should be. The Golf could have been tweaked remember. I've had a Golf TDi pull away from me consistently but I suspect it was tweaked ;-)
Do you have a Mocal cooler fitted?? - just these can have an effect on the amount of oil in the sump depending is the stat is open or not when the oil is changed and when the car is stopped...
Yes mate I do have a cooler fitted but the only reason I have mentioned the oil being over the MAX level is because that is the only thing I can think of that might have affected performance due to a buggered CAT. There are no faults reported with VAG-COM therefore I'm just clutching at straws really!
Yes andy I know that is possible but I have noticed this performance problem for a good few weeks now and yes a RR would do the job but I haven't got the time or the money to do this.
I mentioned in a previous post that the C was tested with a GTech Pro and the results were not good!
It seems like another trip to Stealth is materializing!
LOLOL very true, anyway the problem was the MAF all along, new one fitted and the car is back to normal!!
Cheers peeps
Funnily enough I checked my oil today, first time after a stealth service ... hey presto, overfilled!
I was suspicious when they charged my for 6 litres of oil and didn't find any half-empty cans in the car, but assumed they were more professional than that.
No I don't have an oil cooler...
Time to drive carefully I think. What's the most *reliable* way of draining some oil off? Sump plug? Don't wanna dump it all on the floor in the road outside my house...
If you find a way let me know, cos me and Kev managed to over-fill mine at the weekend.
My current school of thought is the little drain plug in the oil filter housing..
Hmm, this really does p*ss me off, this again just proves that checks are not being carried out. Underfill is always better than overfill, and obviously oil takes time before it completely registers on the stick.
When I carry out an interim service I put 5-5.5 litres in, run the car for 5-10 mins and then top up to desired level.
Yes again a simple mistake that could feck your CAT, totally unacceptable.
Kwik-fit is looking more appealing as I type.
Oh yeah, to update an update, the other problem which was affecting performance.... the vacuum "actuator" which the vacuum line attaches to on the Schrick manifold was fecked. New one bought from Ford (£20), had to adapt it to fit (tap and die job).
1 hour to fit new part, job done, train pull impression has returned.
As far as I could tell the flap was only turning a minute amount. I assume the original actuator had a small puncture.
:lol: So nothing to do with the oil?
I'd still lodge your displeasure with Stealth tho...
No need, Vince has already received my wrath over many oversights, I think it is time to swat up on the VR and undertake all work myself.
I use to do all the work on my previous cars, only with the C did I venture out to the world of mechanics. I have come to realise there is no point, if you do it yourself you know its been done properly, and if it goes wrong you only have yourself to blame.
Oh yeah, you save shed loads of cash as well.
Have you told Stealth about this?
The oil takes ages to collect back in the sump on the VR and as I can testify by removing the sump, there's at least 1/4 litre sitting at the bottom that doesn't get drained....plus what ever is still dripping down the oil galleries. So it's best to put 5.5 litres in, rather than 6..... then check the level in the morning.
A company who specialises in the VR should know this, don't you think?
I've not had chance to speak to anyone at all about it yet..
"put 5.5 litres in rather than 6" - too right, cos 5.5 litres is the book capacity of the VR! If you have an oil cooler it may be different.
This will be the reason why the V5 breezed past you. If the Schrick flap was staying closed past 4k rpm you'd have about 160 bhp odd bhp at your disposal! :oops:
I really doubt the overfill would have destroyed your cat unless it was a massive overfill and your cat was already on it's way out....
If they put 6l in I'd say you're fine. One easy way to find out - go to an MOT station and get a emissions test done.
Admittedly Stealth need to be careful they don't overfill cars, but 6l instead of 5.5l isn't going to ruin cars!
You're right, it's probably not going to ruin anything, but it's not very professional..! Vince is a good guy, but on my past experiences I feel like I need to double check everything they've done all the time, which is not good.
