billinjah
flowing throttle body
i used a belt sander and a dremel, you can also fit a throttle plate? if thats what its called from a 16v golf , as a g60 one has a big lump on it
what sort of bit did you use in the dremmel is what im trying to find out, one of the grinding stones? heard people using flap wheels?
i used a bit that had emory paper wrapped round it,it was good for removing the main bulk and then i used strips of emory paper to shape it.
then got finer and finer with the sand paper/wet n dry,and then autosol 8)
neil.
looks like a little rubber barrel and the sand paper is ready made into tubes
yeah i have these i also have the remote add on which is great to use!
