potatonet 0 Posted June 23, 2005 when I go in a straight line, the oil pressure stays fluent at about 75 psi, about 5.2 bar. the oil pressure sender is located on the side of the head. when gassing it around turns the oil pressure goes down to about 30 psi or 2 bar, I feel that something is wrong here, anyone know of anything? Quote Share this post Link to post Share on other sites
h100vw 0 Posted June 23, 2005 Oil level in the sump could be low and the cornering is sloshing the oil away from the pickup. Is it worse in one direction over the other. The cure is a baffled sump and windage tray from a TDI. Or, of course, more oil. :mrgreen: Quote Share this post Link to post Share on other sites
potatonet 0 Posted June 24, 2005 porbably more oil.... more on left turns than right turns... but is still lowers to about 50 on right turns. Quote Share this post Link to post Share on other sites
Henny 0 Posted June 27, 2005 you need a sump baffle/windage tray... This is a classic sign of oil-starvation due to the oil slopping over to one side of the engine during cornering... Quote Share this post Link to post Share on other sites
potatonet 0 Posted June 27, 2005 well thats good, it will give me an excuse to get a nice aluminum sump at the same time! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted June 27, 2005 What grade oil are you using? Quote Share this post Link to post Share on other sites
potatonet 0 Posted June 28, 2005 20W 50 castrol syntec blend, same as your satin silva or something like that I believe... Quote Share this post Link to post Share on other sites
potatonet 0 Posted June 28, 2005 who changed the forum.... Quote Share this post Link to post Share on other sites
