Niges16V 0 Posted July 6, 2005 Help needed Please! Failed MoT a couple of weeks back on CO emissions so did the full on recon cyl head change with necessary gaskets & seals. Just put it in again today feeling very confident as it is running very smooth, but failed again. It was OK at idle but is giving 0.47% CO @ 2700rpm when pass is 0.3%. It had a new Cat last year for MoT, the timing is spot on, new injector seals, can't think what else it can be unless the hi flow filter has an affect. Any tips would be appreciated as my C is left in the garage for the mechanic to clock a few hours against!! Quote Share this post Link to post Share on other sites
Walesy 0 Posted July 6, 2005 the pannel filter shouldnt mean that you fail emmisions.....lambda probe? Quote Share this post Link to post Share on other sites
h100vw 0 Posted July 6, 2005 It's nowt to do with the CAT. You need to have it checked by a VW specialist. Adjust the mixture requires a 1551 or VAG-COM I think. Gavin Quote Share this post Link to post Share on other sites
Henny 0 Posted July 6, 2005 A dead coolant temp sensor would throw it out by around this much too... Quote Share this post Link to post Share on other sites
