Hellbilly_Racing
1.8 16v Engine Loom
Just a quick one;
Can anyone identify the 3rd plug that is on one end of the engine loom for a '92 Corrado 1.8; the other two plugs being the ECU and the Ignition module. The engine is in a Golf mk1 and came from an accident damaged coupe.
The wires are, in order:
Green/White stripe
Black/White stripe
Red/Yellow stripe
Black/Yellow stripe
Thanks guys
The wires are, in order: 4 way connector refered to??
Green/White stripe - connects to the instrument cluster plug pin 10 via the internals of the fuse box. To do with oil and coolant warning circuit in cluster, purpose not clear as to what the TCI-H switch unit outputs or inputs on this wire.
Black/White stripe - connects to 12 volts from inside a loom
Red/Yellow stripe - connects to earth side of fuel pump relay to switch it on.
Black/Yellow stripe - 12 volts switched "on" by the throttle switch being in the closed position (Idle).
Many thanks peeps,
As this ECU is being used in a MK1 Golf GTi would I be right in thinking that I only need to connect the blk/wht to a 12v source (permanent or ignition?) and the blk/yel to the throttle switch; as the existing fuel pump is already controlled seperatly and the grn/wht is imaterial?
Thanks again
