CaiosG60 PWR 0 Posted July 13, 2005 Folowing on from this thread; Other thread I'm trying to test my Lambda sensor. Am I doing it write according to the attached pictures? Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted July 13, 2005 Now I’ve uploaded that picture. I'm pritty sure I've got my voltmeter set totally wrong! ;-) The reading seams to depend on where I place the negative lead from the voltmeter. When placed on the alternator casing the volt meter was reading 0.4, which if I've done everything right means my lambda sensors caput! Correct?? Quote Share this post Link to post Share on other sites
mk2_20vt 0 Posted July 13, 2005 You've got the mulitmeter set to measure resistance instead of voltage. Switch it round to 20 in the DCV zone and give it another go. edit: looks like you have also disconnected the plug from the lambda, you will need to keep it plugged in and stick you multimeter probe in the back of the plug to pick up the signal wire. Quote Share this post Link to post Share on other sites
GazzaG60 0 Posted July 13, 2005 see the wire thats isolated at the end (bottom on your pic) thats signal. the one you are on ther is either ground or a power wire. Quote Share this post Link to post Share on other sites
Henny 0 Posted July 13, 2005 *edit* post removed 'cos I was being thick... :oops: Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted July 13, 2005 Nice one! With the voltmeter set correctly (thanks golf_20v) I could only get a reading from the one you suggested Gaz. Think I’ve got it right now. Testing where the arrow points now. Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted July 13, 2005 What do you mean exactly Henny? Do I have to leave the plug connected and just read from the wire? I am getting a reading like this with the plug disconnected but am unsure what to make of it. It started at 0.2 at idle but went really high when revving. Also as the engine warmed up the idle reading went up. Quote Share this post Link to post Share on other sites
Henny 0 Posted July 13, 2005 CaiosG60 PWR, ignore me, I was being thick... I'll edit my post... :oops: Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted July 13, 2005 I'm not sure you where Henny! Having just read mk2_20vt edited post I think I know what you meant. Its me being thick! Dooooo :lol: :lol: I'm off outside to try again! ;-) Quote Share this post Link to post Share on other sites
Henny 0 Posted July 13, 2005 ah, OK, that was what I meant... :roll: I thought I'd mis-understood how the probe worked for a moment then... :oops: Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted July 13, 2005 Right finally worked it out now! I'm getting a reading that cycles from 0.18 lowest to 0.89 highest over roughly a second. That means its okay and everything’s working correctly then, right? So it really does use that much fuel! :lol: Here's a picture of how I measured it. Quote Share this post Link to post Share on other sites
Chris VR6nos 0 Posted July 13, 2005 It's like the blind leading the blind this thread! Makes fun reading! :lol: Chris Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted July 13, 2005 :lol: :lol: :lol: :lol: Quote Share this post Link to post Share on other sites
Chris VR6nos 0 Posted July 13, 2005 I also have problems with my lambda probe. I've tried a few things but haven't solved it yet and i'm getting smoke and poor running at times not to mention the poor mpg, i'll suss it shortly. Chris Quote Share this post Link to post Share on other sites
Riley 0 Posted July 13, 2005 i was supposed to test mine today,didnt get round to it...or the isv or the air screw,or the charger :x :lol: Quote Share this post Link to post Share on other sites
CaiosG60 PWR 0 Posted July 13, 2005 While I was working out how to test it I found quite a bit of krud in the connecting socket. It could be because of its position that it’s quite exposed to road dirt. So maybe it did have issues before I messed around with it and cleaned up the contacts. I'll find out if its any different tomorrow when I go for a drive. :-) I hope this thread helps people who are trying to test there lambda. Even I worked it out eventually!! :lol: :lol: Quote Share this post Link to post Share on other sites
