64 SPLIT 0 Posted July 27, 2005 Ran the car to work fine this morning, and out at lunchtime no problems. Get in it to go home and the red coolant light is flashing pretty much straight away. I checked the coolant level last night and it was fine - can't see any leaks either. It usually runs with the coolant between 80 and 90deg's and the oil temp at 92/94 degrees. On the drive home the coolant was between 90 and 100 and the oil temp was up to 100/104 at worst but dropped a few times to 94 deg with the red light flashing all the time. Anyone got any ideas on what to check for first? I've read the 'temperature sky high' thread on here but don't know where to start with this as the coolant temp isn't sky high. Quote Share this post Link to post Share on other sites
Walesy 0 Posted July 27, 2005 when you say you checked the coolant the night before...did you re-check it when the light was flashing? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 27, 2005 It's only a level light so won't be temp related... Check the level and the wiring, the sensors go wrong if normal water has been used for top ups or the coolant is not strong enough, new tanks are about £18 from VAG (bit more if you have a VR) Quote Share this post Link to post Share on other sites
Son of a Beesting 0 Posted July 27, 2005 I had this same thing. I did what corradowales said and found out it was slightly below the level. Apparently if the water in the header tank gets a bit low it can set off the warning light. I added some more water and hasnt happened since. I had it happen when I first started the car in the morning as well! Its an easy and cheap fix and probably best place to start. Hope you get it sorted mate Quote Share this post Link to post Share on other sites
Son of a Beesting 0 Posted July 27, 2005 :oops: just read supercharged post :oops: Maybe using normal water to top up wasnt a good idea!! :( Quote Share this post Link to post Share on other sites
Walesy 0 Posted July 27, 2005 you should be fine if it was only a top up to bring it from slightly under to slighltly over the level shirly...? Quote Share this post Link to post Share on other sites
Son of a Beesting 0 Posted July 27, 2005 Thanks puts my mind at rest anyway. What do you guys do when refilling the whole system? Do you boil the water?? And who you calling Shirly?? ( one of Leslie Nielsen greatest lines!!) :D Quote Share this post Link to post Share on other sites
Walesy 0 Posted July 27, 2005 I use evian...much to the great amusment of my mates. Quote Share this post Link to post Share on other sites
Son of a Beesting 0 Posted July 27, 2005 Oh thats cool, that what I used anyway! It started to over heat in a car park so I had to pay the rip off prices in the drinks machine at the car park. £1 for a small bottle!! I had to get a couple just in case! Thanks corradowales Anyway sorry for the hi-jack. Hoepe you get it sorted 64 Split :D Quote Share this post Link to post Share on other sites
Walesy 0 Posted July 27, 2005 lol..im not sayin you should use it....i would just rather use bottled water than the shet from the tap for the same reason that i'd rather drink bottled water myself than tapwater....im sure someone will be along to call me a pr1ck if im wrong anyhow... :) Quote Share this post Link to post Share on other sites
Son of a Beesting 0 Posted July 27, 2005 Yeah but I like your thinking! Bar getting de-ionsied water (which Im sure some will do!) it sounds like a good idea! Good idea sir :salute: Quote Share this post Link to post Share on other sites
shawshankkid 1 Posted July 27, 2005 Or pour it through a water filter/pureifier first. no substitute for de-ionised though :) . Quote Share this post Link to post Share on other sites
64 SPLIT 0 Posted July 27, 2005 Cheers guys - I think I'm gonna drain the system at the weekend and refill completely - seeing as I haven't got a manual (yet!) what's the best coolant fluid to use and how much will I need? I read on the other post about G11 and G12? What the hoobastanks is thems?! Never heard of em before and can I get it from Hellfords or the likes? Fully agree with you guys about the 'Evian' thing - I used 'Hadrian' (only because that's my name!) in my Scirocco to refill the coolant on there - the water round here develops a horrible scum on the top of it when its boiled so I avoid using it for the car! Quote Share this post Link to post Share on other sites
Walesy 0 Posted July 28, 2005 use G12+ mate... you can get it at GSF etc :D Quote Share this post Link to post Share on other sites
Dutch24V 0 Posted July 28, 2005 My coolant light kept coming on for a couple for weeks with no noticable leak - and then my heater matrix finally blew flooding the cabin with steam. Maybe a coincidence but once I bypassed the matrix no more problem with the light!? Dutch Quote Share this post Link to post Share on other sites
dinkus 10 Posted July 28, 2005 use G12+ mate... you can get it at GSF etc :D And the stealers ;) Quote Share this post Link to post Share on other sites
EDSTARVR6 0 Posted October 23, 2005 I read on the other post about G11 and G12? What the hoobastanks is thems?! Never heard of em before and can I get it from Hellfords or the likes? VW occasionally update the coolant they use. So G12 is newer than G11. Use the most upto date coolant available, but don't mix different types of coolant. G12 is a nice pink colour......helps to find leaks easily........speaking of which :( Quote Share this post Link to post Share on other sites
EDSTARVR6 0 Posted October 23, 2005 woops that top paragraph in the last post "should" have been a quote Quote Share this post Link to post Share on other sites
Walesy 0 Posted October 23, 2005 LOL..G12 is now G12+....you can buy it at the stealers, or in GSF . EDIT--ahhhhhh..i see ..lol Quote Share this post Link to post Share on other sites
cymru-corrado 0 Posted October 23, 2005 i had to run my car on morris univeral stuff today and its gone bang again.well its overheating and pissing coolant everywhere. could it be due to this and not having g12 which is normally in it? Quote Share this post Link to post Share on other sites
