BarneyVR6 0 Posted July 21, 2003 Anyone got any experiences with leads and plugs what with the engine running so hot, good or bad let me know. Quote Share this post Link to post Share on other sites
Joe M 0 Posted July 21, 2003 The best plugs are the standard or platinum ngk ones. I would also be interested in knowing what leads to get. Quote Share this post Link to post Share on other sites
vr6storm 0 Posted July 21, 2003 Anyone got any experiences with leads and plugs what with the engine running so hot, good or bad let me know. i've always been told that the NGK's are the best for coping with how hot the engine can get.........as for the leads not too sure really just like everything else get the best that you can afford Quote Share this post Link to post Share on other sites
vr6storm 0 Posted July 21, 2003 The best plugs are the standard or platinum ngk ones. also joe M the platinum ones are only worthwhile if you have the likes of the vsr fitted as they standard NGK's cost less than half the price of the platinum NGK's and have 20k and 40k service intervals respectively......though its wise to change either a bit more frequently Quote Share this post Link to post Share on other sites
Joe M 0 Posted July 21, 2003 Ill probably change them every 10k so might just go for the normal ones then. Quote Share this post Link to post Share on other sites
BarneyVR6 0 Posted July 22, 2003 Gone for the Magnecor leads and standard plugs but have been looking at the Denso Iridium plugs. Anyone else tried them? Heard good things about them on Jap cars but the VR is a funny engine. Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted July 22, 2003 The VR6 runs the same plugs as a Toyota Celica GT4, so I would presume Jap stuff is fine... They're also the same 5-stud hubs too, since my neighbour has 15inch Speedlines off a VR6 on his GT4 :) Quote Share this post Link to post Share on other sites
BarneyVR6 0 Posted July 22, 2003 All to their own I suppose. I've got some horrible 15" 5 spoke things on mine at the minute. They are coming straight off as soon as my nicely dished 17" League 119 Tanto's arrive wrapped in lovely Toyo Proxes, :D Quote Share this post Link to post Share on other sites
ClassicStorm 0 Posted July 23, 2003 I've got the triple platinum Bosch plug in mine with standard leads,not had any probs with either as far as I am aware!Should the platinum plugs be changed as frequently as the normal ones?Just going slightly away from the topic,I have used the Fully Synth oil from the stealership for the last two changes.Can anyone recommend that I change my ways and turn to Mobil1 or something different........ Quote Share this post Link to post Share on other sites
Rams 0 Posted July 23, 2003 ClassicStorm, Stick with the plugs VW reccommend for your C. The stealers told me that the best oil to use in my VR was castrol Magnetec. My car runs really well with this setup! Just need to upgrade my leads to 8 or 9 ml Quote Share this post Link to post Share on other sites
ClassicStorm 0 Posted July 23, 2003 RAMS Cheers mate,will I need to change the plugs this year again?I will look into the Magnatec oil,fully synth tho I guess?I presume that you are going to go for standard VAG leads?I think I saw a post about the Nology Hot Wires,I thought that they were the daddy's.... Quote Share this post Link to post Share on other sites
vr6storm 0 Posted July 23, 2003 NGK platinum plugs are supposed to last for approx 40k mile intervals........though to be honest they are more than double the cost of the standard NGK plugs which are good for 20k intervals.......so unless you hate changing plugs or have a VSR 8) its not really worth changing to the platinum ones IMHO Quote Share this post Link to post Share on other sites
stormseeker 0 Posted July 24, 2003 .... Just going slightly away from the topic,I have used the Fully Synth oil from the stealership for the last two changes.Can anyone recommend that I change my ways and turn to Mobil1 or something different........ Avoid Mobil 1 it's too thin! I've heard some horror stories of VR6 engines run exclusively on 0W40 from new dying of oil pump failure at 70 to 80k ish miles due to the pressure relief valve in the pump getting stuck in its bore. VW recommend their Synta Silver which is 10W40 I think? Ideally should run 10W40 in winter & 15W40 in summer. Quote Share this post Link to post Share on other sites
ClassicStorm 0 Posted July 24, 2003 I've been running the Synta Gold from the Stealership for 2 changes,that a bad idea? Quote Share this post Link to post Share on other sites
Rams 0 Posted July 24, 2003 Its not a bad idea, VW sell the stuff and woulnt sell rubbish oil for their engines. Im sure there isnt a massive difference ecspecially if you take car with the rev range from when you start your engine from cold. The magnetec is supposed to cling onto you moving mechanical parts very quickly, well that is their moto on advertising, '' your engine is protected from the moment you turn the key''. Your best bet is to change the oil more regulary, I have just thought of it like a hair cut, nice, clean and feeling fresh and ready to get the ladies! Quote Share this post Link to post Share on other sites
BarneyVR6 0 Posted July 25, 2003 The guy that is going to be doing all the servicing on my car for me has said not to use Magnatec because it's "s**t" for VR's as the heat of the engine breaks it down. Quote Share this post Link to post Share on other sites
Chris VR6nos 0 Posted August 6, 2003 I have always ran NGK Platinum BKR5EKUP plugs and Magnatec 10W40 year round with no probs or rattles! Chris Quote Share this post Link to post Share on other sites
Scott 0 Posted August 6, 2003 Ideally should run 10W40 in winter & 15W40 in summer. This is SPOT ON advice..... :lol: 8) Quote Share this post Link to post Share on other sites
